I have added a screw terminal for every connection and a fuse for every circuit.
![Image](http://www.cruisersforum.com/attachments/gallery/4/5/5/9/0/_678239.jpg)
![Image](http://cdn.cruisersforum.com/attachments/gallery/4/5/5/9/0/_687585.jpg)
![Image](http://cdn.cruisersforum.com/attachments/gallery/4/5/5/9/0/_244294.jpg)
![Image](http://cdn.cruisersforum.com/attachments/gallery/4/5/5/9/0/_711449.jpg)
edit made on 27MAY2014 to fix image links
I don't know what engine or alternator is in your CD 27, but I would be surprised if it could output more than 50 amps.My question is, because the same cable is also used for charging the battery, whether a 100 amp terminal fuse is too small for periods when the alternator is charging the battery (particularly when deeply discharged). I am seeing in the literature fuse ratings more in the 250-400 range - but I can't tell exactly how one sizes circuit protection for charging situations.
I printed wiring labels and put them under clear heat shrink tube. I also like to keep wiring diagrams in a binders.What did you use for wire labels?
Hi Russell, I enjoyed talking on Sunday across from the Bean. Please share the details on your choice of panels and their locations. As mentioned, I too will be doing a similar project... and some woodwork... and some major cleaning:) I have not yet decided on what the layout will be but separate panels for AC and DC seems likely.Russell wrote:What did you use for wire labels? Looks like some sort of shrink tube labels? I spent a couple hours today putting together a shopping list for my panel rewire (inspired my Kens unfortunate experience, its something I have put off far too long anyway). Trying to find a good solution for wire labeling and havnt found anything I really love, in the past i have just used white electrical tape and a sharpie pen. But since i can barely read my own writing I do not want to go that route, label makers are spendy though.
I am still in Oriental waiting on some pieces to come in, but I plan to do some detailed posts about the rewire once i get it going. I already took some "before" photos, which I am almost embarrassed to show (its the previous owners on top of poor origonal CD wiring, then me adding too it, its bad).mashenden wrote:Hi Russell, I enjoyed talking on Sunday across from the Bean. Please share the details on your choice of panels and their locations. As mentioned, I too will be doing a similar project... and some woodwork... and some major cleaning:) I have not yet decided on what the layout will be but separate panels for AC and DC seems likely.Russell wrote:What did you use for wire labels? Looks like some sort of shrink tube labels? I spent a couple hours today putting together a shopping list for my panel rewire (inspired my Kens unfortunate experience, its something I have put off far too long anyway). Trying to find a good solution for wire labeling and havnt found anything I really love, in the past i have just used white electrical tape and a sharpie pen. But since i can barely read my own writing I do not want to go that route, label makers are spendy though.
BTW, the upholstery is coming clean by washing machine. That's a load off my plate.
I definitely will take pics. I think I got you beat on wiring messesRussell wrote:I am still in Oriental waiting on some pieces to come in, but I plan to do some detailed posts about the rewire once i get it going. I already took some "before" photos, which I am almost embarrassed to show (its the previous owners on top of poor origonal CD wiring, then me adding too it, its bad).
Glad to hear the upholstery cleaned up, bigger concern will be the foam (thats the expensive part!), and it takes so long to dry once wet, lug it up to your house in VA and keep soaking it and rinsing it all summer. I hope you take a lot of photos and show us all the progress of the project, I have no doubt that the boat will be great once again. Seriously look into a ozone generator, I think that alone will do more to desmoke the boat then anything else will.
I too am in the planning stages of rewiring our CD27. I am really impressed by the neatness of your work. How are those 125A terminal fuses working out. I would like to go with as low a rating as practical. I was planning on 100A for the house battery, but don't know what to go with for the cranking battery. Is the 125A enough?I am using 125A fuses on the positive terminal of the battery banks for a few reasons:
1) The ACR is rated at 120 amps.
2) The starter is rated at 1000 watts nominal. Even if the voltage were to drop to 10 volts, this would draw only 100 amps. So I gave it another 25% to avoid the inconvenience and expense of a blown fuse. In practice, the current is far less than 100 A.
3) The alternator is rated at 55 amp (maybe only 30 - 35 amp max in real world operating conditions and this normally drops quickly as the the internal resistance of the wet cell batteries rises during charging).
4) All the wiring is sized to withstand at least 250 amps for the time it will take a fuse to blow.
5) The purpose of the terminal fuses is mainly to protect against a dead short.
Being in the middle of a long restoration, I have put little load on the 125 amp fuse.How are those 125A terminal fuses working out. I would like to go with as low a rating as practical. I was planning on 100A for the house battery, but don't know what to go with for the cranking battery. Is the 125A enough?
