cape dory 33
chris dehart
cape dory 33
Post by chris dehart »
Is there a number assocated with the plastic slides for the main luff and foot?
Paul D.
Re: cape dory 33
Post by Paul D. »
I believe 3/4 width flat sail slide is the right one. Try these. But If you are at the boat, measure the width of the slide (horizontal across the slide as it sits in the mast slot) to be sure. Could be 5/8 or 7/8 as I am not at the boat but I reckon 3/4.
http://www.sailrite.com/Slide-Nylon-Internal-Flat-3-4
Good luck.
John Martin
Re: cape dory 33
Post by John Martin »
Are your slides the flat type or the ones that the round barrel? Measure carefully. A good source for part numbers is Bainbridge. Most retailers buy from them. Replace all of your slides at the same time, and get a couple for spare.
John & Nancy Martin
CD31 #85 "Carina" 1985
Paul D.
Re: cape dory 33
Post by Paul D. »
Och aye, I done you wrong. The slides for our mail are 7/8 width. All along I was bumming out about not being at the boat to know for sure when I realized the mainsail was down below in my basement! These are the slides that should work.
http://www.sailrite.com/Slide-Nylon-Internal-Flat-7-8
Click on the video tab below the picture for how to install instructions.
Randy Capstick
Location: 1980 Ty Weekender, 1984 CD36 Glen Margaret, Nova Scotia, Canada
Re: cape dory 33
Post by Randy Capstick »
Chris,
The Spartan spar page shows 3/4 inch slides for the CD33 Boom and 15/16 for the mast slides.
Maybe both 3/4 and 7/8 will work though.
Here is a link to the Rigrite Spartan spar page...
http://www.rigrite.com/Spars/Spartan_Sp ... _boom.html
http://www.rigrite.com/Spars/Spartan_Sp ... _mast.html
Good Luck,
Randy
