Hi,
I need to clean the tank and replace all the water related hoses on my CD25. I am planning on just taking the whole mess out, cleaning the tank, and putting the size hose back in...
Has anyone here done any work on their H2O system? Is there any useful improvements that can be made while I am at it?
It seems like a simple task. Any thoughts would be great...
Doug
dmcm@pctech.net
CD25 Questions about water tank & Systems...
Accumulator tank
Excuse my ignorance, but is it a pressurized system with electric pump? If so, I recommend adding an accumulator tank if you don't already have one. It's inexpensive, and eliminates the pressure variation that can make showering so exhilirating as the temperature fluctuates wildly.Douglas McMullin wrote: Has anyone here done any work on their H2O system? Is there any useful improvements that can be made while I am at it?
bilofsky@toolworks.com
Re: Accumulator tank
Excuse my ignorance, too, but does the CD25 HAVE a shower? If so, what year did that start? ThanksWalt Bilofsky wrote:Excuse my ignorance, but is it a pressurized system with electric pump? If so, I recommend adding an accumulator tank if you don't already have one. It's inexpensive, and eliminates the pressure variation that can make showering so exhilirating as the temperature fluctuates wildly.Douglas McMullin wrote: Has anyone here done any work on their H2O system? Is there any useful improvements that can be made while I am at it?
pookpook@crosslink.net
Urk. Well, I guess an accumulator wouldn't be much use on a 25. Please take my remark as a general comment on upgrading on larger boats which have pressurized water systems and showers. As I already indicated, I'm ignorant about CD25s - I just sweep the loose bits off the floor around here and like that.Beth Helms wrote: Excuse my ignorance, too, but does the CD25 HAVE a shower? If so, what year did that start? Thanks
Beth Helms wrote:Excuse my ignorance, too, but does the CD25 HAVE a shower? If so, what year did that start? ThanksWalt Bilofsky wrote:Excuse my ignorance, but is it a pressurized system with electric pump? If so, I recommend adding an accumulator tank if you don't already have one. It's inexpensive, and eliminates the pressure variation that can make showering so exhilirating as the temperature fluctuates wildly.Douglas McMullin wrote: Has anyone here done any work on their H2O system? Is there any useful improvements that can be made while I am at it?
If you need a accumulator please contact Parker Accumulator Division at 815-636-4100.
smmachado@parker.com
