I have a question about the portion of your posting below highlighted in red.
Is your measurement from the center of the keel trough to the center of the pads, or from the gelcoat to the center of the pads?
Thanks again, Bill Goldsmith
Oswego John wrote: Hi Wingreen,
I just measured one of my Tys and came up with these measurements. FWIW, These measurements are CLOSE to what you are looking for. There is no way that I can give measurements on curved surfaces without given a definitive point to measure from. As you know, the Ty's lower hull is ALL curves.
I might add that some of the required measurements being sought are invalid with a full keel boat. So here are some approximations.
1. Distance from bottom front of keel to back of boat? 9' = 108"
2. Distance from bottom back of keel to back of boat? 5'-1"= 61"
3. Vertical distance from bottom of keel to bow eye? No eye. (actually measured to forestay plate). 5'-61/2" = 661/2"
4. Depth of keel (from bottom of keel to where the keel curves out.
1'- 51/2" = 171/2"
5. Distance from bottom of keel to hull at 30" from side of keel? This is an invalid question. For a Ty, 30" is too great a distance for a hull support. This would give you no purchase at all. It is almost to the freeboard.
On the Triad trailer that my Ty is resting on, the centers of the rear adjustable pads are 23" out from the keel. The front adjustable pads are 20" out from the keel.
6. Width of keel at bottom of keel? This is difficult to measure. On the Triad trailer, the Ty keel sits in a padded steel channel iron trough that measures 81/2" I.D.
I hope that this can give you some insight into your new rrailers requirements.
