I have a 1976 Typhoon Daysailer (completely open cockpit) - Last two digits of serial # are 76 and stamped in the fiberglass near the back is a date in October 1975. The Cape Dory plate says this is hull number 47 and the mainsail is #47. From other messages, I'm confused since I would think a 76 would have a much higher hull #. Are the Daysailers numbered separately from the Weekenders? Also, does anyone know when the Daysailers switched from being a completely open cockpit to the partially covered one that is shown in all the literature?
mbork@email.msn.com
Typhoon Question
Re: Typhoon Question
Matt: I have a 1975 Typhoon daysailer with completely open cockpit; hull no. 22. No idea of when they switched over to the partially covered cockpit. As a matter of interest, an article in Soundings that I once saw indicated that of the 2200 or so Typhoons made, about 80 were daysailers and of those 80, about 30 had completely open cockpits. Mark.Matt Orkins wrote: I have a 1976 Typhoon Daysailer (completely open cockpit) - Last two digits of serial # are 76 and stamped in the fiberglass near the back is a date in October 1975. The Cape Dory plate says this is hull number 47 and the mainsail is #47. From other messages, I'm confused since I would think a 76 would have a much higher hull #. Are the Daysailers numbered separately from the Weekenders? Also, does anyone know when the Daysailers switched from being a completely open cockpit to the partially covered one that is shown in all the literature?
mbarth@cm-p.com
check out the following web site. It has interesting info about hull #'s.
www.boatsafe.com/nauticalknowhow.hin.html
rosswilli@aol.com
rosswilli@aol.com
