bow thruster on CD 27
Does anyone have some perspective on how a CD 27 will sail if a previous owner had installed bow thrusters?
T. Duffus
- bottomscraper
Re: bow thruster on CD 27
Thrusters with and "S", like more than one? On a 27? Really? Now that's funny!karonoko wrote:bow thrusters?
I can picture that on a catamaran.bottomscraper wrote:Thrusters with and "S", like more than one? On a 27? Really? Now that's funny!karonoko wrote:bow thrusters?
The idea that I got was he was talking about two directions of thrust, port and stb'd, from one drive.
Whatever,
PS: What we need is a stern thruster(s) when moving in reverse.
"If I rest, I rust"
Voting Member #490
Voting Member #490
- jerryaxler
bow thruster
My bow thruster has minimal affect on sailing. She is on the foredeck with a boathook only when docking.
Fairwinds and following seas,
Jerry Axler
Jerry Axler
Are we speaking of twin tunnel port and starboard thrusters?karonoko wrote:Does anyone have some perspective on how a CD 27 will sail if a previous owner had installed bow thrusters?
![Image](http://img.photobucket.com/albums/v494/dbcamreon/Sunset-at-CoburgWeb.jpg)
- mike ritenour
- Location: " Lavida" - CD33 /"Dorothy" - Open Cockpit Typhoon
bow thruster
If its a known model and not home made, it should not impair your performance.
We put one in our 44'er and it really made a difference in docking but otherwise you didn't know it was there.
rit
rit
"When you stop sailing, they put you in a box"
www.seascan.com
www.michaelritenour.com
http://groups.yahoo.com/group/shorthanded_sailing/
www.seascan.com
- Wingaersheek II
Cape Dory 27 #250
Port Washington, WI
A good kick in the stern will keep most anyone moving in the right direction.Oswego John wrote:PS: What we need is a stern thruster(s) when moving in reverse.
- Warren S
Cape Dory 270 Hull #5
Washington, NC
At least she'll back straight...
"Wow" is all I can say. But honest confession: If I had it, I'd use it! ![Smile :-)](./images/smilies/icon_smile.gif)
![Image](http://i93.photobucket.com/albums/l49/AmpTRookee/morveren03.jpg)
You could always glass the holes back over. Seems like overkill for a 27' boat. Then again if it is there you might find it useful in docking situations. Or just fun to play with in an annoying noisy sort of way.
Most things in life are a compromise. Losing water tankage does not seem like a good trade for the thruster. I have always question how much those holes in the leading edge effect performance. It has to make a difference and especially on a relatively small boat.
A lot of the decision might depend on how you intend to use the boat. If you will be keeping it on a mooring and cruising then the thruster would be of little use. Loss of water, sailing preformance and something else to go wrong would not be good.
If the boat is to be day sailed most of the time and you had to back into a tight slip in a windy location that thruster might seem like a very good thing.
Someone definitely thought it would be a good idea for their situation but yours might not be the same, Steve.
i will be cruising, and this is overkill for me - i can handle a boat! i need the water so will need to put a tank back in - with or without the thruster. i do like toys, so in a tight spot it could be useful, but not without water. Any thoughts on how now to install a water tank?
Or, what would it take to soundly remove the thruster and return her to original?
T. Duffus
- bottomscraper
I'm sure the holes can be glassed over by a competent
fiberglass person. It's not trivial but nothing money can't fix
Ronco Plastics has a decent selection of V shaped tanks, they
had a perfect replacement for the tank on our CD36. They will
customize so you can put the fittings and clean out ports any
place you want.
Ronco Plastics Web Site: http://www.ronco-plastics.com/newRonco/index.php
Ronco Catalog PDF: http://www.ronco-plastics.com/pdfs/MarineTanks2009.pdf
place you want.
- M. R. Bober
Unless you feel compelled to purchase this boat, I would find another CD27. There is--IMHO--too much work involved to undo the thruster installation.karonoko wrote:i will be cruising, and this is overkill for me - i can handle a boat! i need the water so will need to put a tank back in - with or without the thruster. i do like toys, so in a tight spot it could be useful, but not without water. Any thoughts on how now to install a water tank?
Mitchell Bober
Sunny Lancaster, (Where we thrust, but verify.) VA
CDSOA Founding Member
