Best LED replacement bulb for CD berth lights
Paul D.
Post by Paul D. »
I have replaced our overhead light bulbs with Sensibulbs with great results. The newer ones are warmer than the first ones I used. I think the flat square shape of them may not fit in the berth lights though. Has anyone used them in the stock CD early eighties lights? Or do you have a bright LED replacement bulb recommendation?
I had replaced all of my reading lights as the old ones were difficult to keep polished and the bell reflectors were cracking. Once I did that the little pin type LED bulbs were easy to find.
With LEDs you always want to look for warm white unless you need really bright and rather annoying light, Steve.
Troy Scott
old style reading lamp LED
Post by Troy Scott »
Paul,
Go to superbrightleds.com and look at their 1142-WW18-T. I can tell you from personal experience that this is a great product and it will work in your reading lamps. That is if they are the double contact bayonet base type, known as BA15D or 1142. They also have other versions....
Troy Scott
barfwinkle
Post by barfwinkle »
Will their festoon LEDs work in the running lights?
Fair Winds and Warmer Temps
Bill Member #250.
Troy Scott
LEDs for running lights
Bill,
There are some directional festoon LEDs that are designed for running lights. I have encountered them before. I'll make a note to find time this afternoon to find the source.
Troy Scott
wstringer
LED's for berth lights
Post by wstringer »
Paul,
The Sensibulbs fit just fine in our berth lights. I have replaced all the old halogens in our 1981 CD 36.
Warren
Warren Stringer
John Danicic
Nav Lights + cabin lights
Post by John Danicic »
I got one of these for the Series 40 bow light
for Mariah last year. It is two color, red and green and I can report that it works fine. It is indexed with the staggered pins but I did have to "adjust" with a small Dremel Tool grinder, the socket base so the the colors lined up correctly. It puts out a strong light, every bit as bright as the 25 watt bulb it replaced using only one watt. What a savings in power! The stern light is the same bulb in white with no modifications needed to the socket.
The reading light that Troy suggested, the 1142-WW18-T should work well. About five years ago, I got the predecessor to it. It is a spotty, cold light that is highly directional. Dr. Led sells double contact, non indexed reading bulbs as well.
They make a good product and I would recommend them.
Sail on
John Danicic
CD36 - Mariah- #124 on the hard under layers of snow.
CDSOA #655
barfwinkle
Dome Light
So what do you use in the dome light (over the galley and in the head on a 25D)? Tail Brake Turn BA15 PCBs, 1142 BA15D PCBs, T10 PCBs from super bright leds?
Follow the link below and scroll down to PCSs.
http://www.superbrightleds.com/cgi-bin/ ... tm#ba15-pt
Bill Member #250.
I used the flat card type bulbs with the wire connector to the base.
I then got some double stick tape and small plastic clips (3/4" or 1"). I had to cut off one of the legs on the clip where the screw hole is. Then it was simply a matter of double stick, taping the back of the LED card to the flat on the clip. Install the bulb base in the socket and then clip the LED to the base.
It seems to work pretty well.
Some of these bulbs do create a slight radio interference at times, Steve.
John Danicic
Dome lights.
Bill:
I used the Sensibulb in my domes. Image
That is one great, bright bulb that doesn't look like a bulb. I am sure there are now alternatives to them in the form of "normal" looking bulb. Dr Led has a few as well. The times are a changing.
Sail on
John Danicic
CDSOA #655
Troy Scott
Bill,
I've bought several of these for purposes of experimentation. The most important features of these "adaptations" are regulated voltage/current and color. Look for a wide voltage range, like 8-32 or 10-30. If it just says 12, or 24, or some narrow range like 10-14, they are using simple resistors instead of a real regulator. Don't buy those. WRT color, "warm white" is generally pleasing in a boat with teak. Other colors can make your teak look greenish and your green cushions may become blue! However, not all "warm whites" are the same. Read the tutorials on the superbrightleds website. Find one you think you might like and buy just one. Obviously these lamps will work better if all the LEDs are pointed toward the lens. Don't be surprised if it doesn't work out that way. Many of these lamps are available with the connections available in two versions to suit your fixtures better. Be sure to check your fixtures and get lamps that will orient themselves correctly in your fixtures. WRT the "tower style", they work well in reading lamps with a white painted reflective surface. They will also work in dome lights, but they will work better if the reflective surface is polished stainless steel or white painted. Many of our brass dome lights don't have white paint inside. That is not a good thing. Any of these brass dome lights will work much better if the reflective surface is painted white (even if you keep the original incandescent bulbs!). You can find high temp white paint at LOWES, but ordinary paint will work if you're using LEDs. I have also found that the reflective surface can be covered with shiny aluminum tape, the kind they use to seal air conditioning ducts, but without the foam.
LED lighting is a huge and complex subject. I have more answers, too many to list here right now.....
Troy Scott
Troy Scott
flat card
Bill,
What Steve did works well. Some folks have cut off the connector and tried to wire the two leads directly to 12 volts. Don't do it! The regulator is in the connector!
Troy Scott
Troy Scott
That's the one!
Bill, the LED nav bulb replacement that John posted is the one I remember.
Troy Scott
Paul D.
Post by Paul D. »
I recommend the Sensibulb for the overhead dome lights. The one I got last year is a tad warmer in color than the first one I got a few years back. They are both very bright and put off very little heat.
Looks like we have a choice between the sensibulb and others for the berth lights. These are good times for power stingy bastards like us sailors!
2tocruise
Little Creek, VA
Currently in Annapolis, MD
Sensibulbs
Post by 2tocruise »
I replaced all the reading lights (cone style) with the newer version of the sensibulbs. They easily fit, and I've been quite happy with the light they provide.
Sailor's Solutions also has a dimmer switch for use with Sensibulb. I saw it at the boat Show this year and it seems to work well. Might be nice to be able to adjust between background ambiance and task lighting.
Twenty years from now, you will be more disapointed by the things you didn't do than by the things you did do. So throw off the bowlines. Sail away from safe harbor. Catch the trade winds in your sails. Explore. Dream. Discover.
- Mark Twain
