Typhoon Speed
Tom Shone
Typhoon Speed
Post by Tom Shone »
I am interested in a typhoon as a first "larger" boat. A reveiw I read suggested that the top speed is only about 5 knots. Is this true? If not, can you give me some examples of wind conditions and cruising speeds that you've seen. I'm not looking to buy a racer, but that sounds awfully slow.
T Shone
tshone@coopervision.com
Bill Goldsmith
Re: Typhoon Speed
Post by Bill Goldsmith »
Tom:
Here's the formula for theoretical maximum hull speed in knots of a displacement hull:
Square root of the LWL (length at the water line in feet) times 1.34.
Based on the Ty LWL of 13' 6" I get just about 5 knots. However, keep in mind that Carl Alberg designed most of his hulls so that at a few degrees of heel, the LWL actually increases, so you could expect a bit more than 5 knots.
As an example, the LWL on my CD27 is 20 feet which results in a theoretical max hull speed of 5.9 knots. In fact, while motoring I have never achieved a speed of 6 knots, always in the high fives. However, at a few degrees of heel in a fresh breeze I have regularly achieved a hull speed of 6.3 (with new sails). Working backwards, I calculate that while heeled I am getting an effective 2 extra feet of water line length, or about 10% more than flat.
Assuming the Ty design also gives you a similar 10% boost while heeled, you could expect to achieve about 5.5 knots. Now that's the theory. Having never sailed on a Typhoon, I would be interested in whether the theory is verified by the experiences of Typhoon sailors!!
Good luck in your decision process.
Bill Goldsmith
CD27 #173
Second Chance
Tom Shone wrote: I am interested in a typhoon as a first "larger" boat. A reveiw I read suggested that the top speed is only about 5 knots. Is this true? If not, can you give me some examples of wind conditions and cruising speeds that you've seen. I'm not looking to buy a racer, but that sounds awfully slow.
T Shone
goldy@bestweb.net
jhalpo
Re: Typhoon Speed
Post by jhalpo »
I am in my second season owning a typhoon. Compared to larger boats I guess it moves slowly and after a year I realized I would never reach the Gulf of Maine from my anchorage unless I went out overnight.
But a typhoon is not a sailboat for transportation from one point to another. The simplicity and beauty of sailing her make the speed irrevelant.
jhalpo@javanet.com
Pat B
Re: Typhoon Speed
Post by Pat B »
definitely, the trade-offs must be considered. you mention having had a larger boat. does it cost less to own and maintain the smaller typhoon? if yes, then harbor hop your way north and use some money to leave the boat at a marinain between . the typhoon is not great for overnighting compared to larger cruising yachts, ie no amenities, so stay at a classy marina. getting anywhere fast on any sailboat has never happened to me. i've sailed a bunch of different sizes. the whole point is to slow down and enjoy the journey. best wishes, PatB Friend Ship.
PJBallo12@aol.com
Pat B
Re: Typhoon Speed
Post by Pat B »
definitely, the trade-offs must be considered. you mention having had a larger boat. does it cost less to own and maintain the smaller typhoon? if yes, then harbor hop your way north and use some money to leave the boat at a marinain between . the typhoon is not great for overnighting compared to larger cruising yachts, ie no amenities, so stay at a classy marina. getting anywhere fast on any sailboat has never happened to me. i've sailed a bunch of different sizes. the whole point is to slow down and enjoy the journey. another option is to haul the boat to maine, leave it there, drive to where the typhoon is and spend time exploring from a new home port for a season or two. best wishes, PatB Friend Ship.
Pat B
Re: Typhoon Speed
Post by Pat B »
top speed is not the most important criteria for me. when cruising, i want safety, stability and a sea kindly motion. i've got that with the typhoon. this is the type of boat that will take care of you. Pat B 'Friend Ship'
PJBallo12@aol.com
tom shone
Re: Typhoon Speed
Post by tom shone »
Pat,
Thanks for the response. I bought that ty and have been enjoying it on Seneca Lake in NY for the last month.
T Shone
