CD30 Cutter Compression posts
Kevin_P
Location: Former owner of "Meridian"1977 CD30C #58Milwaukee, WI
Post by Kevin_P »
Hi All,
I have a '77 CD30 Cutter with compression post under cockpit. I had always presumed that it was for the mizzen mast, but now I'm wondering if the later CD30s even have or need the compression post at all. Removing it might provide better access to the engine... though it might be more work to remove than the perceived benefits.
Thoughts?
Thanks!
Kevin Petajan
Kevin Petajan
"Vegvisir" - Young Sun 35
1977 CD30C #58
Milwaukee, WI
There might not be any immediate response to this post because no one else has a compression post under their cockpit.
Could it be that a previous owner added this post to correct a soft deck? I have never had a close look at a CD-30 ketch so I don't know what the set up is like. The last thing you need is another impairment to access in the engine area, Steve.
Kevin_P
Post by Kevin_P »
Thanks for the reply. Maybe the earlier CD30 models were all built with the compression post... then at some point, perhaps when they dropped the ketch configuration, they stopped building them with compression posts?
-Kevin
Kevin Petajan
1977 CD30C #58
Milwaukee, WI
JWSutcliffe
Post by JWSutcliffe »
I had a 1981 CD30, which had no such compression post. I cannot even imagine trying to squeeze back there with yet another obstruction!
Skip Sutcliffe
CD31 Oryx
Kevin_P
Agreed!
Post by Kevin_P »
Yes, it's already a mess back there with the V-drive and all, then the post sits about 6" to 8" behind the fly wheel. (engine is mounted backwards) Fun! I'm glad that I'm somewhat skinny, otherwise I'd never make it down there! :-)
Kevin Petajan
1977 CD30C #58
Milwaukee, WI
Klem
Post by Klem »
My 30k has a compression post directly under the mast step for the mizzen. It seems like a plausible hypothesis that all boats used to get this until they stopped producing ketches. It should not be necessary structurally to the boat without a mizzen.
K_LeMans
Raconteur,
Menominee, MI
Compression Post
Post by K_LeMans »
I have a 1981 30c (#216) and it does have a compression post. Who knows how they decided to install them (or not).....
I never thought about taking it out. One could suggest that it provides support to the cockpit sole..... but apparently others get by without it. I wonder if there is any difference in cockpit construction depending on whether the post is there or not.
I'm 6"-2", so going down there is always painful.
Kevin L.
rorik
Post by rorik »
The compression post is there not to support the cockpit sole so much as it it is to stop the mizzen from punching a hole in the sole as the wind picks up and the downward pressure created by the rigging increases.
jvanghel
Compression post
Post by jvanghel »
I have a CD 30c also, #179 and it has a compression post also. Only downside I have seen is crazing in the fiberglass gelcoat above it.
Raven is an early 1984 (309) CD-30C with no compression post.
I believe I now have our hot water heater right where the post would have been, Steve.
