Propane tank location
Ken Cave
Anacortes, WA
Post by Ken Cave »
Sure Marine out of Seattle has the solution of us CD 28s for
a propane installation.
It is a "rail mount kit" (around $70.00) that you attach to a stanchion on the stern for a 1.4 gallon #6 Worthington propane bottle (around $150.00). I actually have three mounted on the stern, and have installed an extra stanchion in the middle of the rail using goodies from Tops and Quality, Inc. They even have a split device that mounts on the existing rail so that one can install a stanchion without cutting the existing railing.
If you do plan to install a complete propane system you are looking about $600.00. This includes LPG Control Kit, hose to fit, and all the goodies you need for a double set up. I have a propane stove as well as a Force 10 propane heater which really helps keep my wife happy in our cold spring and fall weather up here in the northwest!
If you would like some photos an a description of parts needed
please give me your mailing address, and I will send them out shortly.
Ken Cave
CD 28 #227
rorik
Post by rorik »
Ken Cave wrote:Sure Marine out of Seattle has the solution of us CD 28s for a propane installation.
It is a "rail mount kit" (around $70.00) that you attach to a stanchion on the stern for a 1.4 gallon #6 Worthington propane bottle (around $150.00). I actually have three mounted on the stern, and have installed an extra stanchion in the middle of the rail using goodies from Tops and Quality, Inc. They even have a split device that mounts on the existing rail so that one can install a stanchion without cutting the existing railing....
Ken Cave
CD 28 #227
That is the setup I posted pictures of above on my CD28... but only 2 tanks.
Dixon Hemphill
Post by Dixon Hemphill »
To Ken Cave:
Yes I would appreciate your sending me photos and a description of parts needed for the rail mount kit using the #6 Worthington propane bottle.
Dixon Hemphill 10910 Olm Drive, Fairfax Station, VA 22039-1602
Many thanks, Dixon
Within the the unlocked homes of the Swedish villages on the shores of the Baltic around the rocks sings the sea.
Brandon
Fort Lauderdale, Fl
frp lpg tank
Post by Brandon »
To throw another element into this conversation: I have used fiberglass propane bottles for a few years now. They are 50% lighter, rust and corrosion free, and clear so you can see how much fuel is left inside. It's really a great thing if you are looking for a propane tank to use on the water.
The road goes ever on and on,
And I must follow it if I can,
Pursuing it with eager feet,
Until it meets some place
Where many paths and errands meet,
And whither then I cannot say.
B. Baggins
