At this point I removed all hardware from the decks, drilled and filled with epoxy and redrilled correct size.
There was a lot of crazing on the decks, I sanded all the non-skid off and used a dremel (tedious) and routed all of them out and filled and faired with epoxy.
After 7 years a few are creeping back. If I was to do it over again (no chance) I would peel down to the balsa and start over.
Since I did most of the grunt work myself the cost of topsides/non-skid and hull in Awlgrip was about $9500.00.
Hopefully these jpegs are not to big. not sure how to make them smaller.
Lots of hard work but well worth the effort.
