Emptying water tanks at seasons end
jack Kelley
Location: 30 ft. CD cutter 1982 "Marpessa" Hyannis Yacht Club
Post by jack Kelley »
How can you avoid the labor of simply standing and using your foot pump to empty two tanks of water. This may seem simple - but would appreciate any input.
Jack Kelley
Paul D.
Post by Paul D. »
If you can get a wet dry vacuum nozzle in there you can remove it that way. I use that to get rid of extra anti-freeze after flushing it through the lines. Problem is you need to empty it if you have a lot.
Otherwise you could use a drill pump to pump it out.
Jeff and Sarah
Post by Jeff and Sarah »
I suppose you could allow it to siphon to the bilge and let the bilge pump do it's thing. That might not be ideal if the tanks are 100% full though.
Al Levesque
Post by Al Levesque »
Siphoning to the bilge has the added advantage of getting out the water in the lowest corner of the tank if you direct the hose there.
If the boat is going on the hard, you can siphon from the tank to the ground.
Jim Davis
Edgewater, MD
Cut the hose
Post by Jim Davis »
Cut the hose at its lowest point. Put a "Tee" in it with a valve on one leg of the "Tee". The water simply drains into the bilge and gets pumped overboard.
Jim Davis
S/V Isa Lei
winthrop fisher
cd 22 "Easy Rider Sr" 84
Post by winthrop fisher »
go to a pump out station at the docks and do it the right way...
mahalocd36
Post by mahalocd36 »
winthrop fisher wrote:go to a pump out station at the docks and do it the right way...
EWWW I would not put a head pump out hose in my WATER tanks.
Gross.
Melissa Abato
www.sailmahalo.com
Gross.
That gives a whole new meaning to backwash!
Maybe he was thinking that you were talking about draining your holding tank into the bilge and then pumping it overboard. Non of the above suggestions would be very good for that task.
I use a hand pump and shop vac on my water tanks, Steve.
Oswego John
Emptying Tanks
Post by Oswego John »
I go along with Steve. I also think that he was talking about the holding tank.
Oh well, whatever.
"If I rest, I rust"
Voting Member #490
winthrop fisher
sorry i was thinking of your holding tank :oops:
Phil Shedd
Rothesay NB Canada
Membership # 89
Post by Phil Shedd »
I with the vacuum group. I can get the tanks and supply lines dry and remove any dirt that may have got into the tanks. I use antfreeze only in the pump and the pressure lines. The great thing about doing it this way is there is little antifreeze taste in the spring.
I also antifreeze the gray water pump.
Phil
drysuit2
Post by drysuit2 »
What if I still have the anti freeze from last winter still in my tanks?
Can I just leave it for this winter? Or does it go bad?
Ron M.
Post by Ron M. »
Frank, if you are talking about the cheap rv antifreeze it will probably be ok for another winter but I found out the hardway that it does lose it's capabilities after a while......especially in cold climates where it gets down to 0 and below.
________
Vt750
drysuit2
Post by drysuit2 »
Ron M. wrote:Frank, if you are talking about the cheap rv antifreeze it will probably be ok for another winter but I found out the hardway that it does lose it's capabilities after a while......especially in cold climates where it gets down to 0 and below.
Yikes! I guess it's worth it to buy another 6 pack of the pink stuff; just in case.
