I've replaced 6 of 8 of my portlights with Tri Matrix ports from New Found Metals. These six were all 5x12. The two most aft ports are 8x18 or something. I can't find a good direct replacement. I'll probably use the 7x12 Tri Matrix ports.
Check them out at:
http://picasaweb.google.com/toddrtownse ... directlink
CD28 #53 - New Portlights!!
- BubbaThePirate
Eat When You're Hungry
Work When You're Broke
Member #1005
Member #1005
- Roger McManus
- Location: Boat: s/v "Cocos"CD 28' Sloop, Hull #71 Annapolis, Maryland
- BubbaThePirate
Sorry for the insanely late reply, but that is my life these days.
I removed the same wood spacers and replaced with epoxy filler all around. It was an interesting job pushing epoxy with a putty knife, especially "up," but I think it created a very solid foundation. Incidentally, I was able to check as I drilled holes that the epoxy was well past each bolt hole.
Member #1005
Member #1005
