photo take 30
- Cathy Monaghan
Ron,
You need to "share" your photos before you can include them within a posting. Your online photo service should have instructions on how to do that, but usually it's via email. You'll have to share them with yourself, which means having the photo service send you the shared link rather than sending it to a friend or relative. The URL they send you is the one that you use.
Once your have the shared URL, just copy/paste the URL of the photo (must end with a file extensionof .jpg, .gif or .png) into your message posting. Then use your mouse pointer to highlight/select the entire URL. Then click on the "Img" button.
If the URL does NOT end with .jpg, .gif or .png, use the "URL" button rather than the "Img" button.
Cathy
Webmaster-CDSOA, Inc.
<center>==============================================</center>
Need help adding photos to your posts? See the links below.
In the 'About this Board' forum: In the 'FAQs': In 'Need help starting?':
Cathy
- How You Include Photos Within Posts:
In a nutshell, copy/paste the URL of your online photo(s) in the message body of your post. Select/highlight the entire URL, then click on the [Img] button. CLICK HERE for indepth instructions using BBCode then CLICK HERE for instructions using HTML. Please use HTML if your photos are wider than 600 pixels (don't forget to use the "width" command).
