CD25D prop
yachtbroker
CD25D prop
Post by yachtbroker »
Anyone know the correct diameter and pitch of the 3 blade 25D prop?
Kent Little
Kent Little
mgphl52
Post by mgphl52 »
Depends on the HP & output RPMs from your transmission. There were lots of options (from Cape Dory) and she could have been repowered by a previous owner...
-michael
tartansailor
Prop for a CD25D
Post by tartansailor »
I sent you bmail.
yachtbroker
All,
This one has the orginal 1gm Yanmar in her.
Current prop is a 3 blade. If that helps at all.
Thanks.
Kent
Kent Little
John Vigor
Re: CD25D prop
Post by John Vigor »
yachtbroker wrote:Anyone know the correct diameter and pitch of the 3 blade 25D prop?
Kent Little
My former 25D with the identical engine went well with a 3-blade prop, 12-inch in diameter with 9-inch pitch.
John V.
Joe Myerson
I second John V's recommendation
Post by Joe Myerson »
FWIW, I've got a 25D with the original 1GM, and my prop has the same specs as John's.
I'm not sure that the prop is original, as the PO worked for a boatyard and often scavenged parts from other vessels.
--Joe
Former Commodore, CDSOA
--Capt. John Smith, 1627
Dick Kobayashi
Purchase Options
Post by Dick Kobayashi »
...and the place to buy the three bladed prop specified by John V is...? And the cost is...?
Dick K
CD 25D Susan B #104
Mattapoisett, MA
mgphl52
Post by mgphl52 »
If you're looking for new prop and have your full specs (engine, HP/RPM curve, aperture size, transmission gearing,etc.), I would suggest checking out a Campbell Sailor prop.
trapper
CD25D, Lake Murray SC
prop
Post by trapper »
I have an extra 2 blade prop for my 25D with a 1gm. Send me a pm if you are interested
Jeff G
25D Prop
Post by Jeff G »
I've got a three blade Campbel Sailor prop that is 12 inches in diameter with a 9 degree pitch. My engine is the original Yanmar 1GM 6.5 HP
