Does anyone know where I could get opening ports that would fit a Typhoon? I tried 4" ones from West Marine, but there wasn't enough height on the cabin for the flange.
RevDougTanner@aol.com
opening ports for Typhoon
Re: opening ports for Typhoon
Doug,
I looked for this option last year and did not find opening ports that had a small enough flange for the curve of the cabinsides. I ended up with fixed bronze portlights from ABI and they were fairly simple to install and for $100 make the boat look $500 better, easily!. They are the 4" round deadlight model. Get the interior finish ring for the extra $8. Good luck.
Paul Danicic
Typhoon Hornet #1178
Mpls
nyeme001@tc.umn.edu
Paul Danicic
Mpls
nyeme001@tc.umn.edu
Doug: I installed the 4" West Marine working ports on my 79 Typhoon. I had to grind off 1/4" of the flat flange ring.Doug Tanner wrote: Does anyone know where I could get opening ports that would fit a Typhoon? I tried 4" ones from West Marine, but there wasn't enough height on the cabin for the flange.
The inside has enough room. Looks great and the added air flow will be a plus.
Jonathan.D.Dodge@HealthPartners.com
