Hi all,
Can anyone help?
When I put a block for spin halyard on the bail of the masthead, should it be a "swivel" block? Or will this cause the lines to twist sometimes?
Ryan
Sojurner
Chicago
Digistill@aol.com
cd 25 spinnaker halyard block
Re: cd 25 spinnaker halyard block
a standard block with a twisted d-shackle will work for the halyard. the most important location for the swivel is the halyard end-fitting that attaches to the head of the spinnaker
swivel block
i believe that you must have a swivel block. every installation i have seen uses one. it helps not only to prevent a twist when raising the sail, but also to ensure a fair lead when the sail is out in front, to port or to starboard. a twist shackle will not accomplish that, leading to halyard chafe. the sail is always moving a bit, much more so than a jib or main and the halyard may part surprising quickly.
john
john
Re: swivel block
You must use a swivel blockjohn churchill wrote: i believe that you must have a swivel block. every installation i have seen uses one. it helps not only to prevent a twist when raising the sail, but also to ensure a fair lead when the sail is out in front, to port or to starboard. a twist shackle will not accomplish that, leading to halyard chafe. the sail is always moving a bit, much more so than a jib or main and the halyard may part surprising quickly.
john
When the hailard twists...and it will... you need to be able to untwist it.
if no swivel is used you will wind up with one heck of a mess when it beomes twisted!!!!!!!
Mibrinn@aol.com
It is highly recommend you use a swivwl block. I hung a Schaeffer 5-series block with a universal head which allows it to swivel.
