CD Power Boat Shaft Bearing
Frank
Post by Frank »
Has anyone removed the upper shaft bearing on an early model CD cruiser with the 1 1/4" shaft?? Does it have 2 or 4 set screws?
After the set screws are removed, how do you get the bearing out? I am replacing the bearings and installing a PSS shaft seal. Any suggestions.
ccmlake@msn.com
