Is every CD25 jib so...small?
Mr. Doug
Post by Mr. Doug »
Just to test all the rigging, I put the jib up yesterday. The boat was still in the cradle, so it wasn't going anywhere...but I had to see what it looked like.
I was a little surprised how small the jib is on a CD25.
Is there another option for a larger sail? Should I bother?
Doug Hardman
Chris L
Harbor Beach, MI
Post by Chris L »
You likely have a working jib (100%?). It is a good sail to have when the wind picks up, but for lighter winds you will likely want a larger genoa. I have a 145% and it works great in my opinion. I know some people have bigger and others small genoas, you will likely get varing opinions on the optimal size but I think the consensus would be to get a genoa.
Mr. Doug
Post by Mr. Doug »
That's what I thought. I really hope I can find a larger sail that'll work...somewhere.
Heck, I might be able to find something else that may work in the boat-yard. I keep thinking that the #4 on our T10 would have been bigger than this thing.
Doug Hardman
MarcMcCarron
doug - learn about sails
Post by MarcMcCarron »
doug - there are headsails in different sizes depending on wind conditions.
The small ones are for use in heavy wind and the big ones are for light
wind. when your sailing in very heavy winds they get real small.
MARC MCCARRON
Mr. Doug
Post by Mr. Doug »
Marc: Oh I'm well aware of that...I was just a little taken back by the smallness of the only head-sail I got with the boat. (Edit: That sounded kinda rude...didn't mean it to be.)
I'm going to take some measurements tomorrow so I know what I've got now.
Anyone know of a compatible boat I can fine a Genoa from?
Doug Hardman
MarcMcCarron
it works fine in 15-20 knots
the boat has a very large main.
There are used sail traders on the net that have
sails that will fit your boat.
(I had a 25)
You need a 150 for 6 to 12 knots of wind.
The boat really responds to a symmetrical
spinnaker.
Get a drifter for light winds if you don't want to
buy the spinnaker set up.
motor when the winds are 5 and under.
Consider a roller furling headsail if you can afford it.
It would be a 150 that would reduce down when furled.
The boat wouldn't point as well when the sail was furled....
it could be a issue because the boat doesn't point close
under ideal conditions.
MARC MCCARRON
Chris L
Harbor Beach, MI
Re: it works fine in 15-20 knots
Post by Chris L »
MarcMcCarron wrote:the boat has a very large main.
(I had a 25)
spinnaker.
I agree with the state wind speed ranges, that is pretty much what I do. I have hank-on head sails so can't comment on the furler performance, but it certainly would be more convenient!
A 150 is nice for light air but it won't reef down well to working size or less.
Mr. Doug
Post by Mr. Doug »
I think I'm going to look for a 135 to 150 to handle light air, and keep the working jib for heavier air.
Doug Hardman
jbenagh
Salem, MA
Post by jbenagh »
I have a 135 and an old working jib. I use the 135 up to 20-25kts. I put the first reef in the main around 15+ when I start to get too much weather helm.
Jeff
Sea Owl
CD25 Hull#438
Monmouth Beach, NJ
Post by Sea Owl »
I have a 100% working jib which I am now convinced is too small for most days. Works well in higher winds, as others have stated.
Definitely go for at least a 120% or a drifter depending on what you typically see for wind where you are!
Sea Owl
CDSOA Member #1144
KDreese
Hingham, MA
Looking for a CD25 100% Jib
Post by KDreese »
By the way... if anyone happens to convert to roller furling and doesnt need the hank on 100% jib I would be happy to take it off your hands. I have a 120 but would really love a 100%. Just a thought if you are looking for help lowering the overall cost of a roller furling setup. Send me a PM if interested.
Best Regards,
Kevin
"Life begins at 2 knots."
MarcMcCarron
life
No- life begins at six knots if you have a CD.
MARC MCCARRON
KDreese
Hingham, MA
Post by KDreese »
I was thinking boat speed LOL. However, if we talk windspeed I guess life begins at 5-10kts with a CD. I used to autocross my MINI so it was kind of a joke with my wife now that I have slowed down...
