If when sanding the bottom you hit a "thin" area and just a little white (the hull) shows...can you just paint over those areas with the new bottom paint? Thanks...
Larry Austin
CD30MKII
LAYLA
laustin@us.ibm.com
Bottom Sanding ????
Re: Bottom Sanding ????
absolutely as long as the gelcoat is not slick and shiny, the paint needs some tooth to bond properly.
