Boat cover for 19 foot Cape Dorey Typhoon weekender
Hi,
Does anyone have any idea where I might find a winter cover for my boat, or suggestions on how to make one?
I appreciate any help you can give me.
Thank you,
Glenn
Thank you,
Glenn
- David van den Burgh
Winter Cover
I imagine there's someone out there who can offer Typhoon-specific advice, but here's what I did for our CD36.
You can read my notes at our site: Winter Cover
- Joe Montana
Member 781
Simple Tarp
Hi Glenn, I have a day sailer, but I think this would work for a weekender. This very simple and inexpensive system has worked well for me for years: I have a long (about 19') board (about 1x3) that runs from stem to stern. It's flexible and when I tie it down at the bow and afterdeck, it creates a nice smooth arc, with the highest point at the mast step. My mast is keel stepped, so I put a 2x4 up through the deck where the mast would be for the central support; you might only need a cushion on your mast plate. I have another vertical support in the cockpit area.
I reuse the same supports and lines every year, and the whole thing goes together very quickly. To hold it in place athwartship I use lines run to cleats on the cabin top and in the cockpit. I use a large (cheap) plastic tarp that wraps up the entire boat very neatly. A large tarp covers the entire hull, and even most of the bottom.
The first year I worried about not having ventilation, but I've been doing this for many years now and have not had any problems with mold or mildew. I make sure that I cover the boat on a dry, sunny day. Each spring, the boat is as dry as a bone and the only real cost has been to replace the tarp every few years (for under $20). I have no enclosed cuddy, so maybe you would want to give more thought to ventilation.
Good luck.
Good luck.
Boatcover for 19 foot Cape Dorey Typhoon weekender
David and Joe,
Thank you so much! Great ideas! I'll get to work. :D :D
Glenn
Glenn
- Location: CD-27 "Impromptu" Pine Island Marina, Groton CT
Easiest way
We covered our typhoon weekender with the mast unstepped and a cheap tarp from a hardware store or wherever. I lay a 2 x 6 board from the stern to the cabin top (about 7 feet) to make the peak of the enclosure. To prevent the sides of tarp that cover the cockpit from getting weighted down with snow and forming pools, we use 2 of those white plastic resin chairs (super cheap) and lean them toward the 2 x 6 "spine." The chairs form a perfect support system for the tarp. No ice/snow pools in the spring!
Re ventilation, just leave the companionway boards out; we never had a problem.
Paul McCary
Impromptu
Pine Island Marina
Impromptu
Pine Island Marina
Hamilton Marine..
Hamilton Marine sells the good heavy duty green poly tarps that blend in a lot nicer than the bright blue ones. Buy a tarp, some 2X4's and some strapping and you'll have a fine little cover. You can place pipe insulation over the toe rail to prevent chafe of your toe rail and your cover..
- bhartley
CD25D #184 "Pyxis"
CDSOA Member #785
Weighing in on Typhoon Covers
Miranda was covered for the season last October 1 and was finally uncovered in mid-August. Granted there wasn't lots of snow in eastern Massachusetts this winter, but the cover served well nonetheless.
The frame was made from CPVC and was just press-fit (the end piece sprung when I removed the cover). There are 3 vertical pieces - cockpit, mast step and stem from 2x4's with notches. The stemhead piece was bolted in place.
Although it was a silver tarp, it was a very low-end model. Two grommets ripped during summer storms.
Winter Cover
I run a board from the stern to the top of the companionway hatch; at the stern I have an X shaped cross which holds the board at the same height as the hatch. I then take a common tarp and put it over the board & the boat and secure it with line tied to the trailer. Works great.
Greg
