Repowering a CD26
Nick Armstrong
formally NUREL
Point Judith Pond, Rhode Island
Build 1985
Repowering a CD26
Post by Nick Armstrong »
I currently have a Honda 15 and it has gone south. I am considering repowering with a 4 stroke 9.9. I have some current problems, about 5 knots at times and concerned the 9.9 will be adequate. Any comments on an engine for my CD 26 will be greatly appreciated.
Nick Armstrong
jefff
Yamaha 9.9
Post by jefff »
I have a long shaft 9.9T for sale with just a couple hours, PM me if interested.
Jeff Funston
drysuit2
Post by drysuit2 »
I had a similar inquiry last month.
http://www.capedory.org/board/viewtopic ... light=cd26
Thank god I was able to resuscitate my 2 stroke Merc 9.9, because I could not find a suitable [8 horse or better] 4 stroke that would fit in the CD26 Well. The closest I found available, was the Merc 4HP. It is about the same physical size and weight.
Shawn mentioned a Yamaha 8hp high-thrust 4 stroke.
Mike on Kayla also mentioned a Nissan 6hp 4-stroke, but I could not find either locally. That may be a good compromise.
Good luck, and let me know how your search goes as I know I will have to replace mine soon.
Thanks[/url]
mgphl52
Nissan online
Post by mgphl52 »
Hi Folks,
I couldn't find a decent price "locally" either so I bought mine online, from Defender, I think. Just checked them and all they had in stock were 15 hp. Searching further I found this via google "nissan 6-hp 4-stroke" :
http://www.onlineoutboards.com/6hp_niss ... motor.html
Don't know this particular dealer but there were many others to look at as well.
Enjoy!
George Shaunfield
and Westsail 28
Dickinson Bayou, Galveston Bay, TX
Post by George Shaunfield »
Wow, 5 knots of current! You need an motor that can push the boat at hull speed (about 5.9 knots) so that you can make 1 knot of actual progress against that kind of current.
I bought my CD26 in 2003 and it had a 2000 model Yamaha High-Thrust 9.9hp 4-stroke with 25" shaft. The prop is 11.75" diameter and it can really push the boat. I never tried to reach hull speed. A year and a half ago I bought a Tohatsu/Nissen 6hp 4-stroke long shaft to that I could lift it in and out of the lazerette by myself, but then I don't have to content with currents of more than 3 knots maximum. If you are interested in a lightly used Yamaha let me know.
In your situation a 15 hp may be the way to go. It should be the same outside dimensions as the 9.9 which fit without a problem in my lazerette. The mounting board had been relocated about 1" from it's original location.
George
