I would like to mount a bimini on the flybridge of a CD28, however access to the side of the flybridge is very tight and almost impossable to get into to mount any backing plates, nuts etc. Has anyone mounted a bimini on the rail that is attached to the top of the flybridge side. This rail seems to be in about the right spot but my question is whether it will suport the additional weight of the bimini top.
lipari@clinic.net
Flybridge bimini
Re: Flybridge bimini
Peter mine is mounted on the rail and it is quite solid.The hinge fitting is attached just aft of where the forward part of the existing railing curves down and is mounted to the flybridge.I could fax you a picture sence "E" mailing an attachment for me is a problemPeter Lipari wrote: I would like to mount a bimini on the flybridge of a CD28, however access to the side of the flybridge is very tight and almost impossable to get into to mount any backing plates, nuts etc. Has anyone mounted a bimini on the rail that is attached to the top of the flybridge side. This rail seems to be in about the right spot but my question is whether it will suport the additional weight of the bimini top.
Tom
TShel11523@aol.com
Simply cut access holes, through the fiberglass, on the inside of the flybridge cowling below or across from where you would like to mount the brackets. When done, make small teak covers to cover the access holes, attached with oval head SS screws. In fact, the covers look quite nice when done. I used a hole saw to cut the access holes.
Bob
RLCapeDory@aol.com
Bob
RLCapeDory@aol.com
Peter:
My bimini is mounted to the side of the bridge. I cut access holes on each side to mount backing plates. I installed inspection ports in each hole. They look just fine and also afford me access to the antenna leads and mounts. I'd be happy to e-mail you photos if you are interested.
Mark Cline
CD 28 FB #219
"Brandywine"
Annapolis
ma.cline@juno.com
Mark Cline
CD 28 FB #219
"Brandywine"
Annapolis
ma.cline@juno.com
