More sleeping room on CD25
Chris
Post by Chris »
FWIW-
At well over 6Ft tall, and my girlfriend at an even 6'0", we have found that V-berth sleeping is at best an uncomfortable spaghetti bowl of legs! Additionally, we have found that while the starboard setee berth is managable, the "galley" sink on the port side entirely precludes any chance of decent rest. I built an easily removable and stowable board to join the gap between the two setee berths. Thus two can easily (and fairly comfortably) sleep beam-wise across the boat. My board runs from a few inches forward of the bottom companionway step up to the mast-step bulkhead. Using a 4" hole saw, I cut a hole so it is dropped in position over the table post and sits securely on a little lip of 1" teak screwed onto either side of setee berths. By routing a 45 degree chamfer on the teak support lip and a corresponding chamfer on the "gap-filler" board, the downward load that the board is subjected to is directed beam-wise as well as down (at least, I think ;), making it quite sturdy to scamper across when getting up to check the anchor, or water the jellyfish. The board is then pulled up when not in use and tucked away under a berth cushion. An easily fashioned foam pillow goes on top of the "gap-board" to make the whole area a level "bed."
-Hope this helps someone else-
Chris
CD25 "Pilgrim"
cnauta2@towson.edu
cnauta2@towson.edu
John M Freeman
Re: More sleeping room on CD25
Post by John M Freeman »
I have had the almost exact same idea for use on my CD25, but have not implemented it in hopes of incorporating the table, with an additional brace on the long end, into the plan. However, up to this point I have not found a suitable table base, would like one that would raise or lower to the right height, or a 2 piece post that I could break down to make the right height. Any one know of a good base/ post design. I have looked in the West catalog, but have not found a good one yet.
John M Freeman
S/V Nanook
CD25, #287
capn_jack68@yahoo.com
