Yo! A tacking question
Bill
Post by Bill »
Morning Light, a gracious CD28, is a little slow on the uptack. In a wind of say, under 10 knots, the sheets get snagged on the shrouds. I do have shroud covers (just enough to cover them), but the
bowlines keep snagging. Consequently, I lose all the built-up speed to tack, grimmace about the wear and tear, and feel guilty when I force the jib around (only in hairy situations). Obviously it is not the boat's fault, so I NEED some advice. Bill
meislandbill@yahoo.com
Mike W
Re: Yo! A tacking answer
Post by Mike W »
Bill:
The first thing I would do is get rid of the bowlines and two seperate sheets. Just use a single line and double it over. This will reduce the bulk on the jib and probably solve most of your "hang-up" issues.
Also, don't release your jib sheet to soon. A little backwind will make your tack happen much quicker, just be ready to pull in the new jib sheet fast. Otherwise you'll be grinding, and not concentrating on boat speed and direction. Hope this helps,
Mike
"Wakonda" cd25d
Scituate, MA
mwankum@tribune.com
yves feder W1UX
Post by yves feder W1UX »
Mike W wrote: Bill:
Mike
"Wakonda" cd25d
Scituate, MA
Agree completely with Mike! Works absolutely great on our CD27. Just one big jibsheet! The double-over knot never slips; simple as can be. The greater the strain, the more it wants to stay put.
Good luck and enjoy!
Yves
S/V "Alphee"
CD27 #4 (1977)
saltwater@tinyradio.com
Neil Gordon
Post by Neil Gordon »
>>A little backwind will make your tack happen much quicker, ...<<
It will force the bow around, but it will also cut boatspeed.
I agree about using a single sheet doubled over... which is what I'll do next time I replace the genoa sheets. In the meantime, taping over the bowlines will prevent some of the snagging.
Regards, Neil
neil@nrgordon.com
Randy Bates
Re: Yo! A tacking question
Post by Randy Bates »
Bill wrote: Morning Light, a gracious CD28, is a little slow on the uptack. In a wind of say, under 10 knots, the sheets get snagged on the shrouds. I do have shroud covers (just enough to cover them), but the
Splice your two seperate sheets together to make one.
randy.bates@baesystems.com
Chris Scheck
What is a double-over knot?
Post by Chris Scheck »
I am just about to replace the jib sheets on RAGTIME, and one long piece of rope doesn't cost any more than two shorter pieces (with apologies to Arlo Guthrie and Alice's Restaurant) so I'll certainly take your suggestion. But what is a double-over knot? I've always used a bowline in my jib sheets.
Chris Scheck
RAGTIME CD33
Newport
cscheck@aol.com
Anthony P. Jeske
A Knot by any other name..
Post by Anthony P. Jeske »
Chris:
It's also known as a Lark's Head Knot or a Girth Hitch. Try looking it up under those names. If you can't find it anywhere, e-mail me and I can fax you a sketch.
Regards,
Tony Jeske
CD25D #141
Breezy
San Diego
ajeske@ixpres.com
Neil Gordon
Re: A Knot by any other name..
A lark's head is what's used on luggage tags... find the middle of the line, pass the loop though the clew, pull the two ends through the loop and you're done.
Regards, Neil
Chris Scheck
Thank you Neil ...
Thanks for clearing up the mystery of the "lark's head" knot. Everyone knows what kind of a knot is used on luggage tags. Sounds better than what I did ... trying to pass the end of my new line thru the clew of the yankee on our CD33 while under sail and then tie a bowline in it. The clew is about 3 feet above my head.
cscheck@aol.com
