Bilge
Ken
Bilge
Post by Ken »
I noticed my automatic bilge pump was not working. Fuse was blown. It keeps blowing the fuses. I changed the bilge switch that is in the bilge. That did not do it. The fuses keep blowing. Any input on what else I can check ?
Zipwhittle@aol.com
John Dunn
Re: Bilge
Post by John Dunn »
Ken, For starters, you might check to see if your pump shaft is free and rotates. Look and see if the pump impellers are jammed with any kind of debris. I wish you luck. John D.
choppedliveroy@aol.com
Boyd
Re: Bilge
Post by Boyd »
For seconds check all electrical connections.
Boyd
s/v Tern
CD30 MkII
Fort Lauderdale, Fla
John Dunn wrote: Ken, For starters, you might check to see if your pump shaft is free and rotates. Look and see if the pump impellers are jammed with any kind of debris. I wish you luck. John D.
Boyd@wbta.cc
