Just had lazy jacks installed. Not sure if I was doing something wrong or if they are not installed properly. When I tried to pull the main up , it kept getting caught in the lazy jacks. Could someone tell me what is the prcoedure for using the lazy jacks. They worked fine when I dropped the main. Although it did seem like the lines could be further back on the boom { towards the stearn }. How far back should the lines be on the boom ?
Zipwhittle@aol.com
lazy jacks
Re: lazy jacks
Ken, the main will inevitably get tangled up in the lazy jacks UNLESS you are hoisting it when the boat is directly into the wind, especially with the bigger CD's. I had them on my CD25 and I could almost free the main from the lazy jacks with a strong pull-up, but no such thing can happen on the CD-33, much less on the 36. You must be totally upwind with the boom -and main- right in between the lazyjacks when you hoist. Once you get used to them, they ARE a blessing. Enjoy.
Zeida
zcecil@attglobal.net
Zeida
Re: lazy jacks
KenKen wrote: Just had lazy jacks installed. Not sure if I was doing something wrong or if they are not installed properly. When I tried to pull the main up , it kept getting caught in the lazy jacks. Could someone tell me what is the prcoedure for using the lazy jacks. They worked fine when I dropped the main. Although it did seem like the lines could be further back on the boom { towards the stearn }. How far back should the lines be on the boom ?
I don't know what kind of setup you have for your Lazy Jack system .
I have mine configed in such a way that I can keep the leward side jacks down untill the main is fully raised. At which time I can then deploy the lazy jacks on that side of the boom and mast. I have them setup in such a way as to keep them attached to the mast, untill they are needed. Then I can raise them as needed. It works on my 330. I just have keep in mind which way the wind is blowing. Perhaps you can set yours up in such a way. Lots of Luck.
BobMc
odinrav@bellsouth.net
Re: lazy jacks
ken
mine work the same: fabulous when dropping the sail, less so when raising especially if i'm alone, wind is stiff, and powerboats are whizzing around me!
len
md.frel@nwh.org
len
md.frel@nwh.org
