Zinc on fresh water cooled MD7A for CD30
Don Metznik
Post by Don Metznik »
Where would I locate the zinc on my MD7A which has a fresh water cooling system?
don@metznik.com
John R.
Re: Zinc on fresh water cooled MD7A for CD30
Post by John R. »
Don, if you have the Sendure FWC heat exchanger system you will find the zinc on the side of the heat exchanger near the bottom. Make sure it gets changed regularly or the heat exchanger will eventually develop internal leaks. If you suspect any problems with the exchanger remove it and have it cleaned and pressure tested.
Don Metznik wrote: Where would I locate the zinc on my MD7A which has a fresh water cooling system?
