CD25 Outboards that fit
Chuck Gardner
Post by Chuck Gardner »
Just bought a 25. Are there any outboads that the tiller handle goes under the traveler support without removing the handle?
chcabinetry@earthlink.net
jeff funston
Nissan 6 works but...
Post by jeff funston »
Yes and no for my Nissan 6 on a 1981 cd 25, I need to remove the rubber end on the handle (only one screw) but it gives me the 1/2" I needed to work the throttle around the traveler.
jeffNospam@pinn.net
bill
Re: CD25 Outboards that fit
Post by bill »
Chuck Gardner wrote: Just bought a 25. Are there any outboads that the tiller handle goes under the traveler support without removing the handle?
The 5hp Honda 4 stroke's tiller handle will go in up, horizontal, and down positions thus allowing one to slip it into the motor well and through the cockpit opening and under the traveler support without removing handle. Mine was a '99 model. I've heard the new models may be larger, so check to make sure.
Bill
wawillis@toad.net
Dan
Re: Nissan 6 works but...
Post by Dan »
5hp and 6hp Nissan 4 strokes are on sail at BoatUS right now for pretty good prices (believe it was about $1250 for the 6).
Dan
Greg Phillips
Post by Greg Phillips »
Chuck, Just a thought along these lines to consider is the ability to turn the motor while its running. I find on my '76 CD25 that with the tiller handle turned vertical I can steer the boat by turning the motor. To back into my slip I lightly tie my tiller off to dead ahead and steer with the motor. Also, in forward with the tiller hard over and the motor turned the same way I can do a 180 or 360 in a little over her boatlength. I am shopping for a new motor now and would not consider buying/using one without this ability to turn in the well. Greg Phillips, CD25 #469 Linda Lou, Apalachicola,FL
2mileyc@digitalexp.com
