Could someone please tell me what should be the lbs for the pressure
cap on the expanion tank of a Universal M18 diesel engine.
Thanks for responding.
Wally Bennett
wbennett@ymail.yu.edu
CD30b Universal M18
Re: Universal M18, 14 hp., it depends.......
Captain Bennett,
It depends. If you have a hot water heater installed with a surge tank(located in the Starboard lazzerette)and engine heat exchanger, the cap on the engine should be around 12 lbs. The one on the surge tank should be 7 pounds if I remember right. If there is not a hot water system installed, then the pressure cap on the engine should be 7 pounds. Oh, they are not special caps, you can buy any one from any auto parts store, just take the old one with you to compare. If the surge tank is installed, you are actually defeating the venting capability at the engine, it will vent at the surge tank instead if it overheats, thus avoiding losing all the coolant. Hope this helps....your servant Sir, I remain...........
David Stump
Captain Commanding
s/v Hanalei CD-30C
CDSOA Number ONE ! ! !
Nautical Traditions Officer
CDSOA, Inc.
Hailing out of Noank, CT
David Stump
Captain Commanding
s/v Hanalei CD-30C
CDSOA, Inc.
