CD25 Rudder Warning
Jim Myers
CD25 Rudder Warning
Post by Jim Myers »
Well the good news is I caught the problem before it happened. I noticed last fall that my Stainless rudder stock was exposed as the fiberglass had worn away from the leading edge of my rudder. Today I had it checked and by pulling aft on the top trailing edge of the rudder I can separate the rudder from the stock! I am having this repaired and will update this post as it is done. SO........Check your rudders now while on the hard!
CD25 # 824
Fair Wind
Warwick, RI
jmyers@styluscentral.com
Eric
Re: CD25 Rudder Warning
Post by Eric »
Exact same problem here. Am repairing this spring.
ew
Allia
Manchester, MA
Jim Myers wrote: Well the good news is I caught the problem before it happened. I noticed last fall that my Stainless rudder stock was exposed as the fiberglass had worn away from the leading edge of my rudder. Today I had it checked and by pulling aft on the top trailing edge of the rudder I can separate the rudder from the stock! I am having this repaired and will update this post as it is done. SO........Check your rudders now while on the hard!
CD25 # 824
Fair Wind
Warwick, RI
Dan Moore
Post by Dan Moore »
Same problem I had on my Typhoon. Check with Roger at BristolBronze.com. He has a inexpensive plan for repair.
dkm
DMoore@wheelerschool.org
Tom Babington
Post by Tom Babington »
Eric our CD25 is starting to show the stainless rudder post. How hard did you have to pull to get the rudder to separate? Are your doing the repair or is the yard? Lets us know how you make out.
Tom
Stardust
CD25#444
South Dartmouth, MA
tomb5050@aol.com
Jim Myers
Post by Jim Myers »
I am getting a price from my yard ( Brewers Cowesset)
I will post the solution.
Tom Babington wrote: Eric our CD25 is starting to show the stainless rudder post. How hard did you have to pull to get the rudder to separate? Are your doing the repair or is the yard? Lets us know how you make out.
Tom
Stardust
CD25#444
South Dartmouth, MA
