I need to recore a small section of the deck, around two square feet and hate to have to buy a whole 4x8 sheet of marine plywood. Does anyone know of a source of partial sheets?
Joel
s/y Pokey II
'73 Ty Weekender #549
Bayside, NY
Source for Marine Plywood in NYC area (partial sheet)
Re: Source for Marine Plywood in NYC area (partial sheet)
Joel,Joel wrote: I need to recore a small section of the deck, around two square feet and hate to have to buy a whole 4x8 sheet of marine plywood. Does anyone know of a source of partial sheets?
Joel
s/y Pokey II
Bayside, NY
You might try Wood-Ply Lumber in Freeport. They say they specialize in marine grade lumber. Phone # 516-378-2612
Warren Kaplan
(who used to sail Little Neck Bay when I lived off of Bell Blvd back in the early 1970s)
Setsail728@aol.com
Boulter Plywood in Somerville, MA ships anywhere via UPS
What thickness do you need? I might have some 3/4" laying around.
Duncan Maio
Mystic Marine
mail@mysticmarine.net
Duncan Maio
Mystic Marine
You may not need Marine Plywood. Exterior Plywood (CDX) uses the same glue as Marine. The difference between the two is in the voids allowed between the individual ply's.
Joel
s/y Pokey II
Bayside, NY
Stupid question??? Why couldnt you use CDX and epoxy the heck out of it prior to bedding into the deck?????
Bill
cd25d@rhapsodysails.com
Bill
Dennis wrote: You may not need Marine Plywood. Exterior Plywood (CDX) uses the same glue as Marine. The difference between the two is in the voids allowed between the individual ply's.
Joel
s/y Pokey II
Bayside, NY
Joel
s/y Pokey II
Bayside, NY
I have cut into and repaired areas in practically all locations on our CD30 and have found no marine plywood.They used AC or CDX which both use exterior glues.Wetted out with epoxy or polyesther resin exterior plywoods should work just as well at much less $.Marine ply doesn't have any voids,thats really the only difference.
Ron Musk
s/v R&R
CD30c
ccerre@rcn.com
