Standing water in bilge
I have a 1984 CD25D with a shower and head sink that drain into the bilge. How do the CD25D or other CD owners get that water out of the bilge? Thanks for your help,
jss
jssfly@cs.com
jss
jssfly@cs.com
Re: Standing water in bilge
Joe,
NOT GOOD draining that water into the bilge!!! You can never pump it all out and all kinds of odor producing stuff remains there! The same goes for water from the ice box!!! "Adamarie" has a dedicated shower pan under the cockpit sole to catch the water from the shower. There is a small bilge pump in the pan which pumps the grey water overboard. Water from the head sink is overboard via a thru-hull under the sink.
If you are unable to install some type of collection pan, you may be able to funnel the water into a bucket which you can then dump overboard.
Richard Feffer
s/v Adamarie
CD30MKII
RichFef@Prodigy.net
Richard Feffer
s/v Adamarie
CD30MKII
RichFef@Prodigy.net
Joe,Joe Staples wrote: I have a 1984 CD25D with a shower and head sink that drain into the bilge. How do the CD25D or other CD owners get that water out of the bilge? Thanks for your help,
jss
If you do not have the room to follow Dick's suggestion (preferred solution) you'll have to flush and pump with the manual bilge pump. Make the pick-up hose long enough to go to the very bottom of the bilge.
Wild Bill, Any thoughts?
For winter stowage search this site by "garboard drain".
Fair Winds,
Leo
'Evening Light' CD33 #38
macdoreNOSPAM@aol.com
Coquina's head sink is piped to a tee on the galley sink drain seacock, but the shower drains into the bilge.
Don Sargeant
~~COQUINA~~
etc.
Don Sargeant
~~COQUINA~~
etc.
jss
Hello Joe
Rhapsody (sans shower) is rigged in the same manner as your 25D....when I leave the boat for the week, I just pump her as dry as I can, then add a bit of Dawn Dish Soap and mix it up really well...This seems to take care of any odor problems. Then every couple of weeks, I get my 1 1/2 gallon shop vac out and pump the bilge completely dry. With the Ice box and head sink draining into the bilge I cant see keeping it compelety dry esp.. during the sailing season!!
Good luck with your new boat. You'll love the 25D!
Bill
Captain Commanding
S/V Rhapsody (the Original)
CD25D #148
Oklahoma contingent to the NE Fleet, CDSOA
cd25d@rhapsodysails.com
Bill
Captain Commanding
CD25D #148
Joe, get yourself some 1 gallon windshield washer containers and run the hoses through the screw on lids, place them in the bilge, problem solved. If you want something bigger you might be able to pick up a 2 or 3 gallon gas can. When the containers are nearly full, unscrew the lid and dump the content over board.
jss
OK, I purchased a CD25D this fall and I was going to put a electric bilge pump in this spring. No one seems to have offered this suggestion. Am I heading down the wrong path.
Ron V.
Seashine
ronvan@charter.net
Ron V.
Seashine
ronvan@charter.net
Hi Ron
Well I have wanted to install an electric bilge pump for years now, but just havent gotten around to it...Yes that is a good idea, however, the models that I am familiar with still would not pick up all the water in the bilge.......at least in my experience....
Fair winds
bill
Fair winds
bill
Ron Vanosdol wrote: OK, I purchased a CD25D this fall and I was going to put a electric bilge pump in this spring. No one seems to have offered this suggestion. Am I heading down the wrong path.
Ron V.
Seashine
