I have a CD25 with a outboard with a electric start and generator. The electrics are laid out this way. One battery, negative lead off the battery goes to a buss with all negative leads to the buss, including the outboard lead. Also off the negative buss lead to the dynaplate. Positive lead off the battery goes to master switch, all positve leads except for the bilge pump downstream from the master switch. Outboard has a zinc, through hulls are not bonded. My question is should the dynaplate be off the main negative buss? My priority is to reduce any possible electrolytic corrosion with the outboard. Any electrical experts with some thoughts?
tomb5050@aol.com
electrical question
