Winch replacement
Dick Turner
Winch replacement
Post by Dick Turner »
I'm thinking of replacing my Lewmar 30 bronze (original equipment?) 2 speed winches on my CD31 with self tailing equipment. I'm wondering if the bolt hole pattern (5 holes) is common with other winch manufacturers and if not, would new Lewmar models have the same bolt hole pattern as the current winches? Thanks in advance.
SV Mystical
tbrhin1@gibralter.net
Warren Kaplan
Re: Winch replacement
Post by Warren Kaplan »
Dick Turner wrote: I'm thinking of replacing my Lewmar 30 bronze (original equipment?) 2 speed winches on my CD31 with self tailing equipment. I'm wondering if the bolt hole pattern (5 holes) is common with other winch manufacturers and if not, would new Lewmar models have the same bolt hole pattern as the current winches? Thanks in advance.
SV Mystical
Dick,
I replaced the standard orginal equipment Lewmar 7s with new Lewmar 16ST self tailers on my CD27. Because the 16ST are bigger, the base of the winch is bigger. I had to drill new holes in the bronze winch platform for the new winch. I suspect that unless the diameter of the new winch is exactly the same as the old, the holes are not identical. The holes may not line up even if the bases are the same diameter. By the way. If you are going up in size, make sure the new winch will fit on the winch platform and that there is enough room for the larger winch to freely turn. I almost made that mistake.
Warren Kaplan
S/V Sine Qua Non
CD27
Setsail728@aol.com
nancy martin
Post by nancy martin »
SV Mystical
Dick,
We will be replacing the winches on our "new" 31 also. We are moving the new bronze self tailing Lewmar 40s from our CD28 to the 31. We did have to drill new holes in the 28 so we are anticipating having to do the same on the 31. Just be sure to install sturdy backing plates under the winch pedestals.
Where is you boat and what is the hull#?
Nancy Martin
nancy.h.martin@worldnet.att.net
Dick T.
Post by Dick T. »
SV Mystical
Dick,
Nancy Martin
Nancy.
Thanks for the info. Our CD 31, hull number 32, is bearthed in Havelock, NC on the Pamlico Sound.
SV "Mystical"
