Does anyone know if the CD 25 was supplied with a common ground system for the onboard electrics and/or some lightning protection?
My '75 has a plate bolted to the exterior of the keel and some sort of heavy wire/rod that can be felt by reaching thru the forward, overhead v-berth access holes. (I will check for possible electricial continuity between these points after this cold snap ends.)
Jim
jtstull@icubed.com
DC electrical grounding
Re: DC electrical grounding
I think you will find the rod forward is copper tubing venting the fresh water tank.Jim Stull wrote: Does anyone know if the CD 25 was supplied with a common ground system for the onboard electrics and/or some lightning protection?
Jim
I would also like some information on the grounding plate. Mine needs to be replaced this season as it is in bad shape.
Robert
robjfuller@aol.com
Further investigation indicates you are right. Thats where the tube ends up.Robert J. Fuller wrote:I think you will find the rod forward is copper tubing venting the fresh water tank.Jim Stull wrote: Does anyone know if the CD 25 was supplied with a common ground system for the onboard electrics and/or some lightning protection?
Jim
Robert
Our old CD manual would lead one to believe that the 25's came with a grounding system from the factory. Not much detail though.
Jim
jtstull@icubed.com
