dead starter, cheaper solution?
Last Sept. I removed my starter and had it rebuilt because the solenoid went out. I had considered replacing with new 'cause its tough to get to the starter for a guy my size, but the local Volvo dealer wanted $650 for a new one!
Well, this evening the "rebuilt" starter with replaced solenoid once again refused to function, this time only clicking when the key was turned. Both batterys are fully charged. So, it seems that a new starter may be in my future. BUT, I hate to drop so much dough (it interrupts my other pet projects on the 2nd love of my life)!
Does anyone out there have a cheaper source for starters? Or a better idea at all (my ego is under control)?
Thanks for any tips!
Steve Alarcon
CD30 Temerity
Seattle
alarcon@internetMCI.com
Steve Alarcon
CD30 Temerity
Seattle
Re: dead starter, cheaper solution?
Steve;Steve Alarcon wrote: Last Sept. I removed my starter and had it rebuilt because the solenoid went out. I had considered replacing with new 'cause its tough to get to the starter for a guy my size, but the local Volvo dealer wanted $650 for a new one!
Steve Alarcon
CD30 Temerity
Seattle
I am new to deisel (and marine) engines. But I have replaced several auto starters, and have found that sometimes it was the voltage regulator. Do deisels have voltage regulators? Just a thought!
Bill
willie@clnk.com
Sounds similar to intermittant problem I had with Volvo MD-7 in my previous boat. Never found the cause, but tapping on the starter with a soft-face hammer did the trick several times. I think you need to do some trouble-shooting before you go to the dealer.
RitcheyVS@aol.com
RitcheyVS@aol.com
i had had many a hour trying to figure out what is going on with my starter. at first i thought start switch. replaIed it engine worked but then clicked again. i have replaced the ignition wire (gray) bought
new batt cables batt switch and really believe problem is in dirty grounding. I did buy a replacement starter (they ARE NOT marinized) meaning they can exist on other nonmarine engines. I took my starter to a place that rebuilds and they ordered me a new starter for about 100$ .... 490$ cheaper than the marine starter which is exactly the` same as
so if your starter really is bad- put power to it to test buy a starter through a non marine source i keep my boat on ocean so i always am concerned with electrical connections corrosion
best of luck but clicking doesnt nec mean starter is bad
best regards Capeadagio@aol.com
capeadagio@aol.com
Bill wrote:Steve Alarcon wrote: Last Sept. I removed my starter and had it rebuilt because the solenoid went out. I had considered replacing with new 'cause its tough to get to the starter for
capeadagio@aol.com
Steve, before investing any more money, I suggest pulling the engine control panel in the cockpit and checking for any loose connections. That was the problem on my CD30. The wire was just loose enough to allow clicking but not tight enough to start the engine. Good luck.Steve Alarcon wrote: Does anyone out there have a cheaper source for starters? Or a better idea at all (my ego is under control)?
Jerry
Low voltage can be an insidious culprit - The fact that your rebuilt quit on you so soon suggests the possibility of a low voltage problem. The batteries may be fully charged but the connections aren't good somewhere along the way.
rlmeigel@aol.com
rlmeigel@aol.com
Jerry wrote:Steve, before investing any more money, I suggest pulling the engine control panel in the cockpit and checking for any loose connections. That was the problem on my CD30. The wire was just loose enough to allow clicking but not tight enough to start the engine. Good luck.Steve Alarcon wrote: Does anyone out there have a cheaper source for starters? Or a better idea at all (my ego is under control)?
Steve, you didn't metion which engine you have, but I've got the Universal 21 hp diesel. Check the switches on the control panel. On mine if she sits for awhile the contacts in the switches seem to corrode or something. Press in and then work the button back and forth clockwise and counterclockwise. This seems to clean the contacts. Get the glow plug hot and then let up for a second and press the plug switch and the start switch in at the same time or work them back and forth one and then the other. It's never failed to start, but sometimes you have to fuss with it a little. Also happens when the engine is hot such as at a fuel dock where you just stop for a minute.
Jerry
TacCambria@thegrid.net
I am not familiar with the exact model you have or its accessability, but it can be tested without being removed by jumping across the two big terminals on the solenoid. if the starter, battery and battery cables are ok, it should turn over merrily. Use a big wire to jump, as it gets hot.Steve Alarcon wrote: Last Sept. I removed my starter and had it rebuilt because the solenoid went out. I had considered replacing with new 'cause its tough to get to the starter for a guy my size, but the local Volvo dealer wanted $650 for a new one!
Steve Alarcon
CD30 Temerity
Seattle
bone2@norfolk.infi.net
I found the problem!!!
Thanks to all who responded to my plea for help. I followed the consensus and spent a few hours trouble shooting yesterday. I found that the ground wire from the battery to engine was loose and corroded at the engine. Once clean and tight everything was fine.
alarocn @internetmci.com
Steve Alarcon wrote: Steve Alarcon
CD30 Temerity
Seattle
Re: I found the problem!!!
glad it worked out if theres a problem ive lived it
with my boat I really have to have things tip top to sail on ocean
best regards don
capeadagio@aol.com
best regards don
Steve Alarcon wrote: Thanks to all who responded to my plea for help. I followed the consensus and spent a few hours trouble shooting yesterday. I found that the ground wire from the battery to engine was loose and corroded at the engine. Once clean and tight everything was fine.
CD30 Temerity
Seattle
capeadagio@aol.com
Glad to hear you solved your problem! If you should find yourself in the market for a new starter, we have one that's almost-new. We had to replace ours awhile back, then ended up replacing the entire engine. We'll make you a good deal!
SkywindMCM@aol.com
SkywindMCM@aol.com
