removing CD-27 tiller attach collar
chuck yahrling
Post by chuck yahrling »
I can't figure out how to remove the bronze clamp-on fitting that attaches the tiller to the rudder shaft. I see a key, and have soaked everything in wd40 but there must be a trick to getting it off the rudder shaft. Anybody know how to do this?
TIA
yahrling@cybertours.com
Duncan Maio
Re: removing CD-27 tiller attach collar
Post by Duncan Maio »
Chuck:
The easiest way to remove the collar - or any similar fitting pressed onto a shaft (like a propeller) is with a gear puller. It is basically three or four hook-shaped arms attached to a plate, with a threaded rod that passes through the plate. The arms hook onto the bottom of the collar, and the end of the threaded rod sits on the end of the shaft. Screw the rod in, and the arms pull the collar off.
Auto parts stores sometimes rent these (for pulling gears, clutch plates and transmission parts), and your boatyard may have a rig designed specifically for propellers that might work.
Good luck.
-Duncan
chuck yahrling wrote: I can't figure out how to remove the bronze clamp-on fitting that attaches the tiller to the rudder shaft. I see a key, and have soaked everything in wd40 but there must be a trick to getting it off the rudder shaft. Anybody know how to do this?
TIA
dmaio@worldnet.att.net
