Pilot Light & "Bedding" ??'s
Bill
Post by Bill »
Hello to All
Well she's getting closer to the water.... Now just a couple more small chores and drop her in. (Unfortunately work is interferring (sp) with progress, Damn the luck).
Now the questions: I need a new pilot light for the electrical panel. WM only has small ones. Where can I get a replacement?
and
some of the "sealant" or "Bedding" used to hide the screwheads of the screws that secure the seacocks are exposed. What should I fill these in with? 4200? Epoxy?
Thanks in advance
Bill
S/V Rhapsody
CD25D
cd25d@rhapsodysails.com
Bob Loewenstein
Re: Pilot Light & "Bedding" ??'s
Post by Bob Loewenstein »
I replaced my pilot light by going to Radio Shack and finding the smallest amperage 12v lamp they had. Thy actually had two types and not knowing which would fit better I bought both. The one I wound up using was packed with a twin, all for about $1.40. I think it uses about 20 mA, but can't remember. You don't need much light and you certainly don't want the battery to run down with this lamp on.
I thought of using an LED, but this little incandescent was a very low user of current. A sufficiently bright LED may use as little as a few mA.
If you find a lower amperage solution, please post.
Bob
Bill
Post by Bill »
I installed the radio shack lights today. The 1/2" light just snapped right in...
Sorry, but I didnt check the amps.
Thanks for the advise.
Fair Winds
Bill
Bob Loewenstein wrote: I thought of using an LED, but this little incandescent was a very low user of current. A sufficiently bright LED may use as little as a few mA.
Bob
