This may seem rudimentary but.........I seem to remember reading awhile back some discussion about just where the jib sheets run - either inside the shrouds, or outside. I have a CD22 and just aft of the shrouds is a padeye mounted on the deck......is this where my working jib sheet runs- inside the rigging then on to the winch? And then does the Genoa sheets run outside the rigging to the jib fairlead? I have tried it this way and it seems fine. Any comments would be appreciated.
Pat
patturner@earthlink.net
jib sheets
Re: jib sheets
Pat,Patrick Turner wrote: This may seem rudimentary but.........I seem to remember reading awhile back some discussion about just where the jib sheets run - either inside the shrouds, or outside. I have a CD22 and just aft of the shrouds is a padeye mounted on the deck......is this where my working jib sheet runs- inside the rigging then on to the winch? And then does the Genoa sheets run outside the rigging to the jib fairlead? I have tried it this way and it seems fine. Any comments would be appreciated.
Pat
You are correct. The setup sounds exactly the same as that on my TY SR.
rjshea@ibm.net
