Port side bulk head
egagnon62
Port side bulk head
Post by egagnon62 »
I am the owner of a Cape Dory 25(1977) for 4 years. When I first purchased the boat there was a gap in the bulkhead on the port side, where the partition between the aft "salon" and head. The gap is now about a fingers width. I have read that this is a common occurrence in this particular model. Does anyone know if this has an affect on the integrity or structure of the boat. (see photos attached). Thank you! Cheers!
Carl Thunberg
Re: Port side bulk head
Post by Carl Thunberg »
I hate to see a post go un-answered, so I'll get the conversation started. Full disclosure, I sold my CD25 at least a decade ago. This is really not a bulkhead in the traditional meaning. It is not tabbed to the hull and is not structural. It's really a modesty panel. I know of at least two CD25s that have removed it and replaced it with a curtain. What is that rack in the bottom photo? Does it bear any weight? If so, that couId be the culprit. looks like it might fit a foldup salon table, but the CD25 came standard with a pedestal mounted table.
Sir Isaac Newton
egagnon62
Post by egagnon62 »
Thank you for joining the discussion and sharing your knowledge. I have spoken to others since posing this question and have found what you say is true. It is not a structural concern. What you see in the bottom picture is a rack for books and I have had nothing in it.
Thanks again!
Cheers!
