Greetings, My need is to replace the Spreader assembly on a Typhoon Daysailer. Need to locate a source for hardware. Do not need to use origional parts. This is not a restoration, it is a repair.If anyone can suggest specific part numbers and sources it would be helpfull.
Charles
cwdev@email.msn.com
Typhoon Sailboat Model TYD
Re: Typhoon Sailboat Model TYD
______Charles deVarennes wrote: Greetings, My need is to replace the Spreader assembly on a Typhoon Daysailer. Need to locate a source for hardware. Do not need to use origional parts. This is not a restoration, it is a repair.If anyone can suggest specific part numbers and sources it would be helpfull.
Charles
Charles,
You have already tried WWW.RIGRITE.COM for the orginal Spartan spare parts? I know these include the spreader tube, end fitting or spreader base...
Dana
darenius@aol.com
