I have the service manual for my Volvo TAMD 40B. Nowhere does it say how much coolant is in the cooling system. Among other spring commissioning projects, I'm planning to flush the cooling system and put in fresh coolant. My question is, how much coolant should I buy? I've searched various sources and came up empty on this relatively simple question.
On the flip side, I also need to know how much old coolant I need to dispose of.
Edit on 4/6/23. Upon further research, there is no clear answer. It all depends how many hoses you are willing to remove in the process. I don't think I want to remove the heat exchanger hoses to the water heater for example because it's virtually impossible to collect. I'm going to do a gravity drain and call it good. Definitely better than nothing.
Engine Coolant - How Much?
Sir Isaac Newton
Sir Isaac Newton
Re: Engine Coolant - How Much?
Same issue with my TAMD40B. I drained out an amount (can't remember how much) and put the same back in.
