Does anyone know what bulb I can replace this with on a CD26 mast? I have spoken with Boat US, West Marine, Anchor Lighting, and GE. So far no one has been able to find a replacement. Does anyone have a suggestion on another bulb that will work?
DGarrity@Allstate.com
Mast Bulb GE212 12V6W Searching for replacement
Re: Mast Bulb GE212 12V6W Searching for replacement
___________DGarrity wrote: Does anyone know what bulb I can replace this with on a CD26 mast? I have spoken with Boat US, West Marine, Anchor Lighting, and GE. So far no one has been able to find a replacement. Does anyone have a suggestion on another bulb that will work?
There are two lamps for the mast. The CD26 is the same as the CD25D. The running light (top) is a two prong bulb. Under the removable 1/4 cover cap you will see "USE ethier 1052? or 1152? bulb which I believe is an auto bulb) I have used an Ancor 1004 which is 12V, 12W, 15CP, .94A. For the lower deck light I have used an auto double end cap style bulb such as #577.
daenius@aol.com
