Looking for advice/rudder question
IanA
Post by IanA »
So, probably the first of many questions….
New to me CD25, late 70’s vintage. Started sanding, and noticed this, right away. The rudder shaft is exposed, along the whole length. Maybe previous owner got a little aggressive with the sander? Can I get away with epoxy fairing, or should I chisel out the gudgeon, remove the rudder, and get a couple of layers of glass, over the whole thing? If there is a plate, attached to that shaft, which is sandwiched in between glass, I’d feel better about the whole thing, but it’s hard to tell.
Re: Looking for advice/rudder question
here are a few photos of mine.. I paid the yard guys big bucks
finished
s2sailorlis
Post by s2sailorlis »
if you do a search in this forum you'll find several rudder repair examples to help inform your decision.
______________
Rick
1984 CD22
IanA
Post by IanA »
On it, thanks! Looks like I’m ok structurally, but I might still put a layer or two, of glass, over the shaft. Not a ton of room, between rudder and hull.
Khaos13
Post by Khaos13 »
Nice work. Looks great!
CD 30 MkII Hull # 8
Ft. Lauderdale, FL
