Propane Locker w/ 2 aluminum tanks (sold)
Skipd
Post by Skipd »
This was taken off a 1986 CD30 cutter that was recently purchased. Everything was working when removed.
The locker looked to be factory installed(?). The drain connection went through the aft cockpit floor to under the transom. 4 bolts through the cockpit floor secured it. This was a fresh water boat and there is minimal corrosion. Was used as a helm seat too as seen in the picture. I like the aft cockpit to be more open and will be hanging a tank off the stern pulpit.
Included are:
fiberglass locker, lid
2 Worthington 10 lb aluminum tanks. One has been re-certified. Both are in excellent condition.
Pressure regulator (replaced a few years ago) w/ gauge
Solenoid (galley control not included)
From what I understand the locker needs a lid gasket and fitting through cockpit to be ABYC compliant. There is a center piece of hardware and wood bracket to secure the tanks.
Can send more photos if interested.
Located in Boston area.
Asking $375
