I bought a Polyform A4 buoy for my mooring back in 2014. This will be its 8th season. It sits in salt water May-October and in my shed over the winter.
The material at the top of the ball has changed appearance over the years--it's now discolored, rough, and kind of sticky to the touch. You think it's time to replace the buoy or is this merely cosmetic?
These are commonly used around here for moorings but I don't really know what the service life is.
Thanks for any tips.
this mooring buoy OK?
- Megunticook
Re: this mooring buoy OK?
Mine are about twice that age. These things just don't wear out. They gradually lose air, but that can be fixed. They clean up reasonably well with lacquer thinner, but you're not going to make an old mooring buoy look like a new one. I'm guessing cormarants are roosting on the top of your ball. Mine look nothing like that.
Sir Isaac Newton
Sir Isaac Newton
If you want to stop the deterioration and have an “as new” appearance try Duplicate-Color vinyl and fabric coating. It’s what car restoration pros use on dashboards and door skins. I’ve used it on old cowl vents. Just sand lightly, wipe down with acetone, spray several light coats so you don’t get runs. It’s durable and cheap and last for several years.
Auto parts stores and big box stores frequently stock it.
- bottomscraper
I don't think it will fail any time soon. Maybe you could paint a giant Kraken on it to scare away the birds
Rich Abato
Nordic Tug 34 Tanuki
Southern Maine
http://www.sailmahalo.com
Southern Maine
- Megunticook
Not concerned about looks, just failure.
I contacted Polyform, they said after a while you can develop cracks and then it can deflate.
Talked with my mooring guys also, they were unequivocal: replace it now or you'll head out to your mooring to find it resting on the bottom one day.
Had picked up a spare at the spring sale at Hamilton Marine so will be retiring the old one.
Not worth the risk. 7 seasons out of a $80 item works for me.
