As I plan a roller furling headsail on my CD28 I have to decide how high the bottom of the drum needs to be off the deck (the sailmaker needs to know the length available for the sail). The issue is clearance for the anchor. Measuring with the anchor in place is pretty straightforward. But I'm trying to envision what I need for room when retrieving the anchor (no windlass). Interested in anyone's experience with this dimension.
It seems the lower the better from a sailing perspective, but banging the anchor chain against the drum isn't recommended.
As always, interested in opinions.
Roller furling drum height
Moderator: bobdugan
- Jerry Hammernik
Lake Michigan
Jerry Hammernik
Re: Roller furling drum height
I took this picture just after I had removed my sails for the season. My headsail furling drum does not interfere with the anchor whether it’s raised by hand or with the windlass. My headsail also has a tack pendant, about three inches long, so the sail doesn’t touch the bow rail.Jerry Hammernik wrote:As I plan a roller furling headsail on my CD28 I have to decide how high the bottom of the drum needs to be off the deck (the sailmaker needs to know the length available for the sail). The issue is clearance for the anchor. Measuring with the anchor in place is pretty straightforward. But I'm trying to envision what I need for room when retrieving the anchor (no windlass). Interested in anyone's experience with this dimension.
