MD7A Diseal leak
bfb
MD7A Diseal leak
Post by bfb »
On my MD7A I have a small Diseal leak at the advance mechanism bolt. I replaced the aluminum rubber washer but the leak is still there
When I bought the washers they sent me three different types
I used the aluminum rubber washer because that was the type that was in there
The other two are copper type
The injector pump is CVA model 32220F70
Any help would be appreciated
See attached pictures
Thank you
Billy
bfb
Re: MD7A Diseal leak
Post by bfb »
Here’s the picture of the advance mechanism the nut on left
mgphl52
Post by mgphl52 »
Switch to the copper compression washers. Note, they are not intended to be "reused"...
Frenchy
Post by Frenchy »
Hi- I think you meant to say the advance mechanism is on the right in the picture, not the left. Yes,
if there's nothing else that can cause that leak, try the copper washer. Use the torque recommendation
in your manual, or if there isn't one, look up the bolt size in a torque table.
The general recommendation is to throw away the copper compression washer and get a new one if
you ever loosen the connection. However, a frugal yankee will reuse the old one by annealing it. Heat it to
a cherry red and plunge into cold water. That will "re-soften" it. Good luck - Jean
Frenchy wrote:However, a frugal yankee will reuse the old one by annealing it
That’s going well beyond frugal and entering the realm of parsimonious :D
Even I have never reused a crush washer.
Frenchy
Post by Frenchy »
Yeah, Jim, we're pretty parsimonious around these parts. I save junk mail envelopes for making shopping lists
and you know those frozen fruit bar sticks? My doctor cleans them for tongue depressors. Much cheaper than
the store-bought ones. :D
bfb
Post by bfb »
Hi
I will try the copper washer.
Thank you
Billy
