I have a 1976 CD25 with the old style fixed plexiglass ports for the main cabin with plastic frames. They are approximately 7"h x 30"w. These may or may not be original equipment. I suspect replacements at some point.
The plastic frames around the ports are worn out, broken, and will not allow me to seal the ports watertight.
Does anybody know where I can get replacement frames and/or portlights that will fit the elongated opening?
Many thanks for your help
Bill Vogel
bill@eysales.net
904-234-8779
Replacement ports for 1976 CD25
Re: Replacement ports for 1976 CD25
Try Spartan Marine in Georgetown, Maine. www.spartanmarine.com They made most if not all of the original bronze hardware for older Cape Dorys.
If memory serves me correctly, I believe the early fixed ports were a bit larger than the later opening bronze ports.
That is correct. The older CD25s had elongated ports, and the Spartan bronze opening ports will not fit the opening. You aren't likely to find a replacement that fits your existing opening. However, if you were somehow able to find a CD25 with aluminum frames that is being scrapped for parts, you may be able to swap the plastic frames with the aluminum frames. It's a long shot. Otherwise, I'm afraid you're into some fiberglass work to get a replacement port that fits.
By the way, the plastic frames are original.
Sir Isaac Newton
Sir Isaac Newton
